So I got a shock pump today and I am wondering......
the pump inlet screws onto the valve and then a second knob must be turned to open the valve and let the air in.( Its liek a little secondary turning knob that has a pin that opens the valve)
I pump it see the pressure but then when I undo the knob to stop the air from going in/coming out I hear a little air escape.
Because the air pressure is so high I wonder if when I read the pressure this air that escapes contirbutes to that reading and that means when I undo the knob and I hear air going out the actual reading is then less.
When I use the air outlet knob its so sensative you just touch it and the PSI drops by 10-20 psi . I am just wondering when I read is it really that accurate once I undo the pump .If a little air escapes the reading drops
Any case that is what logic tells me.
