I have a silverback storm 1 and I see there is a little bit of play on the front wheel . When I hold the steering bar and move the wheel from side to side there is about 2mm of play .Shoudl it not be tight?
I checked the spacers between the hub and the fork is seated correct. The axle is hand tightened to the max .No tool to make it tighter . Is this normal?
  1. Same bike here I get this if I don`t turn the axle in tight enough. With the qr lever still open make sure you tighten the axle enough.
shucks I feel a bit like an idiot checked it out the lever falls back into the opening so that it can be tightened so its fine now .
I could not understand how to tighten the bloody thing with my hands its seemend impossible :clap:
