http://extremelights.gocommerce.co.za/wp-content/uploads/sites/66/2013/08/B20-BLACK-Front-502x502.jpg
http://extremelights.gocommerce.co.za/wp-content/uploads/sites/66/2013/08/B20-Black-set.jpg
http://extremelights.gocommerce.co.za/wp-content/uploads/sites/66/2013/08/B20.jpg
The B20 is Niteye’s strongest cycle light tested to ANSI FL-1 standards, it produces 1200 lumens. The two reflectors, each hosting a Cree XM-L U2 LED, are designed to throw a beautifully balanced beam best suited for extreme cycling. Manufacturers specs:
  • Light source: 2 x Cree XM-L U2 LEDs
  • Material and finish: Aircraft grade aluminium and HA III anodizing
  • Rated max lumen: 1200
  • Modes and runtimes: 1200lm – 2h30 / 600lm – 5h / 100lm – 35h
  • Battery pack: 4400 mAh Li-ion cells in a neoprene pouch
  • Water resistance: IPX 6
  • Dimensions: Length: 55mm / width: 46mm / depth: 31mm
  • Fitted weight: 439 g
Features:
  • Battery gauge
  • Constant current regulation
  • Quick release mount
  • Remote switch
As with the B10, there is no fault with the finish and quality of the B20. The B20 adds a second LED in its own reflector as well as Niteye's patented battery level indicator on top of the light. It shares the same battery pack, remote switch and quick release mount used with the B10. The B20 emits twice as much light as its smaller brother while only adding 29 g in weight. Sharing the same battery pack results in compromised runtimes, with the max runtime at 2.5 hours. Thanks to the battery level indicator, one has no excuse running flat and being unprepared. The beam pattern speaks for itself (see picture). It is extremely wide and floody while still illuminating 100+m in front of you. If your need is not to make light in front of you but to be seen there is always the the strobe function. This mode quickly alternates between the two LED, giving a very distinct indication that you're there. The B20 is an excellent light and hard to fault. Click on any of the pictures for more info.
