Bottom Bracket PF30 to Shimano BB30
Pieterg
I bought a 2014 Specialized Epic Comp bike with X9 Group set .I want to change the group set to Shimano XTR  3x10 but the bottom bracket is the problem, I can’t find a Shimano PF bottom bracket is there a conversion that I can change to?
Press fit frames can easily take the larger spindle size, making way for the pf30 or bb30 style cranksets. These two are basically the same thing with a spindle diameter of 30mm. Shimano still uses the BSA system which has a spindle diameter of 24mm. Sram has a GXP system that is also 24mm or in some cases 22mm. There are adapters available to fit almost everything to anything, and especially one that fits over a BSA or GXP crankset with a 24mm spindle that makes it possible to fit it into the larger bb30 or pf30 bottom bracket.
But as Mike said, there are also pressfit/pf bottom brackets that has a 24mm inside diameter for the BSA or GXP cranksets.
Bottom Brackets:
http://www.cwcycles.co.za/product/shimano-press-fit-bb-mtb-smbb91-42a
http://www.cwcycles.co.za/product/alero-shimano-ceramic-press-fit-bb
http://www.evobikes.co.za/components/bottom-brackets/shimano-press-fit-bottom-bracket-hollowtech-ii-sm-bb71-41c.html
http://www.evobikes.co.za/components/bottom-brackets/rotor-bb-pressfit-4124.html
The one thing you have to watch out for is the spindle length. The PF frames has a smaller bottom bracket shell allowing for a smaller spindle length. So putting your XTR crankset on a PF frame might result in the spindle being too long. You might get spacers for that, But I am not sure. Make sure you get the right spindle length to fit your frame
