Boost/Non-Boost Hanger/Dropout Compatibility
Brick_Top
Good day fellow comrades
I am currently in a spot bother and require the hub's all-knowing expertise.
The hanger on my Big Wig (2017) is slightly bent.
Unfortunately I am unable to source a 148*12 mm replacement hanger but I am able to locate 142*12 mm dropout kit.
Will a 142*12 mm dropout be compatible with a 148*12 mm Through-Axle?
Essentially would a non-boost dropout work with a boost frame/axle?
Looking forward to your feedback.
Thanks,
