Will the following combo from chainreaction work with my Scott Scale 40 hardtail?
Front Shock Post Mount.
Rear shock IS Mount.
Do I need any adapters for the mounts?
Should I consider any other hydrolic brakes?
What year Scale 40 you got? Is it the whole bike or are you looking to piece one together?
Reasons for asking - the 2008 model comes with a fox f100 RL fork and Juicy 3.5 - so what you are looking at would not be an upgrade (if you have the whole bike already)
Yup - my vote will also be on the Juicy's rather than dissimilar brakes.
Will look weird will one silver lever and one black
The fork should be fine, will need an adapter at the back.
no, bought the frame and manitou black elite shock last year think it is a 2004/2005 model. Moved my old parts over from a giant atx with avid disc brakes.
Upgraded my wheelset on my Anthem and mobed the old wtb xc lite rims to the scale, The shock and brakes are not the greatest at the moment.
Swopping the Shimano for the juicy 5 seems like a good idea for the money.
What Discs should i go for.
2 x
Avid Roundagon Rotor - Ball Bearing 5 Only
In Stock Now: 160mm 6 Bolt - FLOOD
4570
120.59 ZAR
or
Brakes Disc Rotors - 58 Products
E-mail Friend
Our Best Selling Brakes Disc Rotors
http://www.chainreactioncycles.com/Images/Models/150/756.jpg
http://www.chainreactioncycles.com/Images/Models/150/3486.jpg
http://www.chainreactioncycles.com/Images/Models/150/15263.jpg
Shimano Disc XT 6-Bolt RT75
Now 180.77 ZAR
RRP 235.62 ZARSave 12%
Hope Disc Mono Mini/M4
Now 241.18 ZARhttp://www.chainreactioncycles.com/Interface/Offers/SaleAndClearance.gif
RRP 346.70 ZARSave 20%
Avid Clean Sweep G2 Rotor
Now 277.24 ZAR
RRP 360.43 ZARSave 12%
http://www.chainreactioncycles.com/Images/Models/150/9950.jpg
http://www.chainreactioncycles.com/Images/Models/150/17120.jpg
http://www.chainreactioncycles.com/Images/Models/150/16457.jpg
Hope Disc Bolts - Torq Head Threadlock
Now 48.12 ZAR
Shimano Disc XTR Splined RT97
Now 241.06 ZAR
RRP 346.56 ZARSave 20%
Hope Disc Mono 6 Saw Disc
Now 289.42 ZARhttp://www.chainreactioncycles.com/Interface/Offers/Sale.gif
RRP 416.04 ZARSave 20%
Sort By Modelhttp://www.chainreactioncycles.com/Interface/Icons/SortBy.gifRatinghttp://www.chainreactioncycles.com/Interface/Icons/SortBy.gifRankhttp://www.chainreactioncycles.com/Interface/Icons/SortBy.gifPricehttp://www.chainreactioncycles.com/Interface/Icons/SortBy.gif
Brakes Disc Rotors
Alligator Wind Cutter Rotor
High grade stainless steel rotor from Alligator ? Superior heat dispersion ? Light weight ? Weight - 88g
180.77 ZAR
RRP 277.22 ZARSave 25%
http://www.chainreactioncycles.com/Images/Models/120/0.gif
More Info
Atomlab Wave Rotor
Features: ? Stainless steel disc rotors ?CD? cross drilled, converts air through the centre of the disc ? ?VVT? ? Vertical Vibration Tolerance ? Heat resistance to eliminate warping ? 3 Sizes available ? Wave ?8? has 8 vents for max cooling ? An ....
7653
204.88 ZAR
RRP 249.49 ZARSave 6%
http://www.chainreactioncycles.com/Images/Models/120/31197.jpg
More Info
Avid Clean Sweep G2 All Mountain Rotor
Avid Disc Brake Rotor Cleansweep G2 with standard 6 bolt pattern. ?Size - 185mm ?6 bolt
In Stock Now: 185mm 6 Bolt
11332
325.48 ZARhttp://www.chainreactioncycles.com/Interface/Offers/Sale.gif
RRP 415.90 ZARSave 10%
http://www.chainreactioncycles.com/Images/Models/120/30560.jpg
More Info
Cross Country, All Mountain, Freeride, Downhill Available in 140, 160, 185 and 203mm (Used on all Avid hydraulic disc brakes for 2007) Specifications: ?Weight: 411grams ?6 bolt, with Sizes: 140/160/185/203mm
In Stock Now: 203mm 6 Bolt | 160mm 6 Bolt | 185mm 6 Bolt | 140mm 6 Bolt
http://www.chainreactioncycles.com/Interface/Icons/StarOn.gifhttp://www.chainreactioncycles.com/Interface/Icons/StarOn.gifhttp://www.chainreactioncycles.com/Interface/Icons/StarOn.gifhttp://www.chainreactioncycles.com/Interface/Icons/StarOn.gif
127
277.24 ZAR
http://www.chainreactioncycles.com/Images/Models/120/15263.jpg
More Info
Avid Disc Bolts - Torq Head Threadlock
A pack of six Avid Torq head disc rotor bolts.
In Stock Now: 6 Pack
564
36.06 ZAR
RRP 48.40 ZARSave 14%
http://www.chainreactioncycles.com/Images/Models/120/20302.jpg
More Info
Avid G3 Clean Sweep Rotor
Varying cutout sizes and shapes vastly improve heat dissipation, which in turn greatly reduces heating of the brake fluid creating a consistent braking feel. It also sheds approximately 10g over the G2 Clean Sweep rotor design. ?Compatible with ....
In Stock Now: 140mm 6 Bolt | 203mm 6 Bolt
10696
301.36 ZAR
RRP 388.17 ZARSave 11%
http://www.chainreactioncycles.com/Images/Models/120/31677.jpg
More Info
Standard round disc rotor to suit the avid disc brakes. High quality steel.
In Stock Now: 185mm 6 Bolt | 160mm 6 Bolt | 203mm 6 Bolt
716
216.94 ZARhttp://www.chainreactioncycles.com/Interface/Offers/Sale.gif
RRP 291.09 ZARSave 14%
http://www.chainreactioncycles.com/Images/Models/120/8890.jpg
More Info
4570
120.59 ZARhttp://www.chainreactioncycles.com/Interface/Offers/SaleAndClearance.gif
RRP 291.09 ZARSave 52%
http://www.chainreactioncycles.com/Images/Models/120/9738.jpg
More Info
Dirty Dog Ace Rotor
Dirty Dog rotors are designed with the newest design tools including 3-D design software and design stress analysis. These tools allow engineers to generate very detailed designs and simulate their performance in cyberspace before ever making a ....
In Stock Now: 203mm 6-Bolt
12067
542.54 ZAR
RRP 692.71 ZARSave 10%
http://www.chainreactioncycles.com/Images/Models/120/25149.jpg
More Info
Dirty Dog Alien Rotor
In Stock Now: 160mm 6-Bolt
14348
542.54 ZAR
http://www.chainreactioncycles.com/Images/Models/120/25150.jpg
More Info
Dirty Dog Bone Burner Rotor
http://www.chainreactioncycles.com/Interface/Icons/StarOn.gifhttp://www.chainreactioncycles.com/Interface/Icons/StarOn.gifhttp://www.chainreactioncycles.com/Interface/Icons/StarOn.gifhttp://www.chainreactioncycles.com/Interface/Icons/StarOn.gifhttp://www.chainreactioncycles.com/Interface/Icons/StarOn.gif
8602
542.54 ZAR
http://www.chainreactioncycles.com/Images/Models/120/25155.jpg
More Info
Dirty Dog Dragon Rotor
9005
542.54 ZAR
http://www.chainreactioncycles.com/Images/Models/120/25153.jpg
More Info
Dirty Dog Gecko Rotor
In Stock Now: 160mm 6-Bolt | 203mm 6-Bolt
14347
542.54 ZAR
http://www.chainreactioncycles.com/Images/Models/120/25148.jpg
More Info
Dirty Dog Highroller Rotor
18371
627.07 ZARhttp://www.chainreactioncycles.com/Interface/Offers/Sale.gif
RRP 970.07 ZARSave 26%
http://www.chainreactioncycles.com/Images/Models/120/25152.jpg
More Info
Dirty Dog Skull Rotor
In Stock Now: 160mm 6-Bolt | 185mm 6-Bolt | 203mm 6-Bolt
9505
530.60 ZARhttp://www.chainreactioncycles.com/Interface/Offers/Sale.gif
RRP 692.71 ZARSave 12%
http://www.chainreactioncycles.com/Images/Models/120/25147.jpg
More Info
Dirty Dog Tadpole Rotor
14948
434.13 ZARhttp://www.chainreactioncycles.com/Interface/Offers/Sale.gif
RRP 692.71 ZARSave 28%
http://www.chainreactioncycles.com/Images/Models/120/25151.jpg
More Info
Formula Oro Hardware Kit 160mm
Formula Oro Hardware Kit which includes a 160mm Oro Rotor and a Formula Brake Mount.
In Stock Now: Front 160mm IS Mount
1868
241.06 ZAR
RRP 277.36 ZAR
http://www.chainreactioncycles.com/Images/Models/120/18747.jpg
More Info
Formula Oro Hardware Kit 180mm
Formula Oro Hardware Kit which includes a 180mm Oro Rotor and a Formula Brake Mount.
In Stock Now: Front 180mm Fox 40 | Front 180mm Boxxer
1228
301.36 ZAR
http://www.chainreactioncycles.com/Images/Models/120/18748.jpg
More Info
Formula Oro Hardware Kit 200mm
200mm hardware kit from the Formula Oro range. Includes disc rotor, mount and bolts. ?Front mounts types - Boxxer, Fox 40, IS mount, Mr T (20mm), Post mount. ?Rear only available with IS mount. ?Size - 200mm
In Stock Now: Front 200mm Fox 40
1616
301.36 ZAR
http://www.chainreactioncycles.com/Images/Models/120/18749.jpg
More Info
Formula Oro Hardware Kit 220mm
Boost your braking power with this Formula Oro Hardware Kit which includes a 220mm Oro Rotor and a Formula Brake Mount.
In Stock Now: Front 220mm IS Mount | Front 220mm Boxxer | Rear 220mm IS Mount
10775
566.66 ZARhttp://www.chainreactioncycles.com/Interface/Offers/Sale.gif
http://www.chainreactioncycles.com/Images/Models/120/18750.jpg
More Info
Formula Oro Hardware Kit 220mm - Alu Rotor
Boost your braking power with this Formula Oro Hardware Kit which includes a 220mm Oro Rotor with a lightweight alloy carrier and a Formula Brake Mount.
In Stock Now: Front 220mm Fox 40 | Front 220mm Post Mount
9033
711.49 ZARhttp://www.chainreactioncycles.com/Interface/Offers/Sale.gif
RRP 872.99 ZARSave 6%
http://www.chainreactioncycles.com/Images/Models/120/18752.jpg
More Info
Funn Disc Rotors
Funn disc rotors in various sizes to match your braking system. ?Sizes - 160, 180 or 203mm ?6 Bolt.
14567
277.24 ZAR
RRP 346.56 ZARSave 8%
http://www.chainreactioncycles.com/Images/Models/120/29506.jpg
More Info
Hayes 9" Hardware Kit
Upgrade your disc size for 45% more stopping power than a standard 6" rotor with this new 9" rotor and mounting hardware.
In Stock Now: 9" Rotor Inc. Boxxer Mount | 9" Rotor Inc. 6" to 9" Post Mount | 9" Rotor Inc. IS 20mm Mount | 9" Rotor Inc. 8" to 9" Post Mount | 9" Rotor Inc. Fox 40 Mount
9624
663.13 ZAR
http://www.chainreactioncycles.com/Images/Models/120/20028.jpg
More Info
Hayes Disc Hayes Mudcutter
The Hayes Mud Cutter Rotor design clears the pads of debris. ? Weight: 116g
In Stock Now: 6" 6-Bolt Wavy Rotor
3045
421.95 ZAR
http://www.chainreactioncycles.com/Images/Models/120/8278.jpg
More Info
Hayes Disc Hayes V6
Hayes V6 The Hayes V6 Rotor is our lightest rotor at 114g. V cut design has more power and increased pad contact area. Perfect for XC. Weight: 114g.
In Stock Now: 6" 6-Bolt Rotor
569
301.36 ZAR
http://www.chainreactioncycles.com/Images/Models/120/8280.jpg
More Info
Hayes Disc Hayes V7
New for 2005, the Hayes V7 rotor give you more power without the weight penalty of the 8" rotor. Perfect for front or rear application. Weight: 156g.
In Stock Now: 7" 6-Bolt Rotor
3625
361.65 ZAR
http://www.chainreactioncycles.com/Images/Models/120/14451.jpg
More Info
Hayes Disc Hayes V8
Hayes V8 Disc The Hayes V8 Rotor is our most powerful rotor option. V cut design has more power and increased pad contact area.Pefect for Downhill and Freeride. Weight: 204g.
In Stock Now: 8" 6-Bolt Rotor
556
421.95 ZAR
http://www.chainreactioncycles.com/Images/Models/120/8281.jpg
More Info
The New re-designed disc bolts form Hope, no longer the allen key head.
In Stock Now: Pack Of 6 Bolts
178
48.12 ZAR
http://www.chainreactioncycles.com/Images/Models/120/9950.jpg
More Info
Hope Disc Bolts Countersunk
Set of 6 Disc bolts with a flat countersunk Allen key head for use with a countersunk drilled disc.
2898
36.18 ZARhttp://www.chainreactioncycles.com/Interface/Offers/Sale.gif
http://www.chainreactioncycles.com/Images/Models/120/1426.jpg
More Info
Hope Disc Bolts Titanium
Arguably the Lightest Disc Rotor Bolts on the Market at the Minute.
In Stock Now: Pack Of 6 Titanium Bolts
335
180.77 ZAR
RRP 208.02 ZAR
http://www.chainreactioncycles.com/Images/Models/120/8290.jpg
More Info
Hope Disc Closed2
Disc rotor for the Hope Closed 2 brake system. Available in a choice of sizes and hole drillings to suit most disc hubs. Complete with fixing bolts.
In Stock Now: 185mm 5-Bolt | 185mm 6-Bolt INTL STD | 165mm 5-Bolt | 165mm 6-Bolt INTL STD | 165mm 5-Bolt Grimeca | 205mm 6-Bolt INTL STD | 145mm 6-Bolt | 205mm 5-Bolt
1707
168.83 ZARhttp://www.chainreactioncycles.com/Interface/Offers/Sale.gif
http://www.chainreactioncycles.com/Images/Models/120/463.jpg
More Info
Hope Disc E4/DH4
Disc rotor for the Hope E4/DH4 brake system. Available in a choice of sizes and hole drillings to suit most disc hubs. Complete with fixing bolts.
In Stock Now: 165mm 6-Bolt
12117
http://www.chainreactioncycles.com/Images/Models/120/18785.jpg
More Info
Hope Disc Hayes
Disc Rotor for the Hayes disc brake system manufactured by Hope Technology. 6" or 8" sizes available in a 6-bolt fitting for International Standard hubs or 5 bolt for Hope BigUn hubs. Complete with Fixing bolts.
In Stock Now: 8" 5-Bolt | 6" 6-Bolt INTL STD | 8" 6-Bolt INTL STD | 8" 4-Bolt Coda | 6" 4-Bolt Coda
2310
http://www.chainreactioncycles.com/Images/Models/120/2491.jpg
More Info
Hope Disc M4/E4/DH4
Disc rotor for the Hope M4 brake system. Available in a choice of sizes and hole drillings to suit most disc hubs. Complete with fixing bolts.
In Stock Now: 185mm 5-Bolt | 185mm 6-Bolt INTL STD | 165mm 6-Bolt INTL STD | 205mm 5-Bolt | 205mm 6-Bolt INTL STD | 155mm 5-Bolt
734
192.95 ZARhttp://www.chainreactioncycles.com/Interface/Offers/Sale.gif
RRP 291.23 ZARSave 24%
http://www.chainreactioncycles.com/Images/Models/120/882.jpg
More Info
Hope Disc Magura SL Wavey Rotor
Hope rotor for Magura SL disc brakes. Standard 6 bolt rotor with Wavey design which helps dissipate heat.
In Stock Now: 160mm 6-Bolt Louise-Clara-Julie
10530
361.77 ZAR
http://www.chainreactioncycles.com/Images/Models/120/11036.jpg
More Info
Hope Disc Mini System
Disc rotor for the Hope Mini brake system. Available in a choice of sizes and hole drillings to suit most disc hubs. Complete with fixing bolts.
In Stock Now: 185mm 5-Bolt | 165mm 5-Bolt | 165mm 6-Bolt | 185mm 6-Bolt | 145mm 5-Bolt | 145mm 6-Bolt | 205mm 6-Bolt | 205mm 5-Bolt
440
241.18 ZARhttp://www.chainreactioncycles.com/Interface/Offers/Sale.gif
http://www.chainreactioncycles.com/Images/Models/120/191.jpg
More Info
Hope Disc Mono 6
Two part floating disc included with aluminium centre and hardened stainless steel braking area reduces weight in these larger disc diameters and handles extremes in temperature on long Alpine descents Use - Downhill or Freeride
In Stock Now: 183mm 6-Bolt Floating Disc - Black | 203mm 5-Bolt | 183mm 6-Bolt Floating Disc - Blue | 183mm 6-Bolt Floating Disc -Gunmetal | 183mm 6-Bolt Floating Disc - Silver | 183mm 6-Bolt Floating Disc - Red | 203mm 6-Bolt Floating Disc - Blue |
3778
289.42 ZARhttp://www.chainreactioncycles.com/Interface/Offers/SaleAndClearance.gif
RRP 346.70 ZARSave 4%
http://www.chainreactioncycles.com/Images/Models/120/12410.jpg
More Info
These Floating rotors are now a firm favourite amongst both performance orientated riders and those just looking for something a little different. These rotors have a stainless steel braking surface riveted to an aluminium central carrier. As we ....
In Stock Now: 183mm 5-Bolt | 183mm 6-Bolt Floating Disc - Black | 183mm 6-Bolt Floating Disc-Gold | 183mm 6-Bolt Floating Disc-Gun Smoke | 183mm 6-Bolt Floating Disc-Red | 183mm 6-Bolt Floating Disc-Silver | 203mm 5-Bolt | 203mm 6-Bolt Floating Disc-
217
http://www.chainreactioncycles.com/Images/Models/120/16457.jpg
More Info
Hope Disc Mono 6-Pot
Disc rotor for the Hope Mono Ti 6-Pot brake system. Available in a choice of sizes and hole drillings to suit most disc hubs. Complete with fixing bolts. To reduce weight on the larger disc sizes the Stainless Rotor is mounted onto aluminium spider.
In Stock Now: 185mm 6-Bolt Floating Disc - Black | 185mm 5-Bolt | 205mm 5-Bolt | 205mm 6-Bolt Floating Disc - Black | 225mm 6-Bolt - Suits Fox 40 - Black
1223
http://www.chainreactioncycles.com/Images/Models/120/3488.jpg
More Info
Disc rotor for the Hope Mono M4 brake system. Available in a choice of sizes and hole drillings to suit most disc hubs. Complete with fixing bolts.
In Stock Now: 140mm 4-Bolt Coda | 140mm 6-Bolt | 200mm 5-Bolt | 200mm 6-Bolt | 160mm 4-Bolt Coda | 160mm 6-Bolt | 180mm 4-Bolt Coda | 180mm 6-Bolt | 200mm 6-Bolt Floating Disc - Black | 180mm 6-Bolt Floating Disc - Black | 140mm 6-Bolt Floating Disc
74
http://www.chainreactioncycles.com/Images/Models/120/3486.jpg
More Info
Hope Disc Mono Mini/M4 Saw Disc
New Hope Rotors feature a mud clearing brake track design. Suitable for the Mono Mini and Mono M4 brakes. Available in a choice of sizes, hole drillings and with a floating rotor or standard one piece design. Complete with fixing bolts. Features ....
In Stock Now: 140mm 4-Bolt Coda | 140mm 6-Bolt | 203mm 4-Bolt Coda | 183mm 6-Bolt | 203mm 6-Bolt | 140mm 6-Bolt Floating Disc-Black | 140mm 6-Bolt Floating Disc-Blue | 140mm 6-Bolt Floating Disc-Gun Smoke | 140mm 6-Bolt Floating Disc-Gold | 140mm 6-B
240
301.48 ZARhttp://www.chainreactioncycles.com/Interface/Offers/Sale.gif
http://www.chainreactioncycles.com/Images/Models/120/16448.jpg
More Info
Hope Disc Mono Trial
Two pot disc brake system developed by hope in conjunction with the multi time world championship winning Koxx Trials Team. With the best input from top riders and the best technology from hope, this is the first brake ever that has been designe ....
In Stock Now: 160mm 6-Bolt | 180mm 6-Bolt
5528
http://www.chainreactioncycles.com/Images/Models/120/6052.jpg
More Info
Hope Disc Shimano XT
Disc Rotor for the Shimano XT disc brake system manufactured by Hope Technology. 160mm or 203mm sizes available in a 6-bolt fitting for International Standard hubs or 5 bolt for Hope BigUn hubs. Complete with Fixing bolts. Features: ?160mm or 20 ....
In Stock Now: 203mm 5-Bolt | 160mm 6-Bolt INTL STD | 203mm 6-Bolt INTL STD
2510
http://www.chainreactioncycles.com/Images/Models/120/3256.jpg
More Info
Hope Disc V2 Rotor
Hope Disc V2 Rotor Increase your braking power with this 203mm statndard floating rotor.
In Stock Now: 203mm - 6-Bolt Floating - Black | 203mm - 6-Bolt Floating - Blue | 203mm - 6-Bolt Floating - Gold | 203mm - 6-Bolt Floating - Gun Smoke | 203mm - 6-Bolt Floating - Red | 203mm - 6-Bolt Floating - Silver | 183mm - 6-Bolt Floating - Black
1875
http://www.chainreactioncycles.com/Images/Models/120/16365.jpg
More Info
Hope Disc V2 Vented Rotor
The amazing new Vented (Patent. Pend) Rotor is available ONLY FOR THE MOTO V2 BRAKE. It is not retrofittable to the Mono range of brakes. It is wider than a standard or floating rotor. This rotor takes braking performance to a new level. Using t ....
In Stock Now: 203mm - 6-Bolt Floating - Black | 203mm - 6-Bolt Floating - Blue | 203mm - 6-Bolt Floating - Gun Smoke | 203mm - 6-Bolt Floating - Silver | 203mm - 6-Bolt Floating - Red | 203mm - 6-Bolt Floating - Gold
8373
832.08 ZARhttp://www.chainreactioncycles.com/Interface/Offers/Sale.gif
RRP 1192.65 ZARSave 20%
http://www.chainreactioncycles.com/Images/Models/120/16364.jpg
More Info
Hope Disc XC4
Disc rotor for the Hope XC4 brake system. Available in a choice of sizes and hole drillings to suit most disc hubs. Complete with fixing bolts.
In Stock Now: 160mm 6-Bolt INTL STD | 150mm 6-Bolt INTL STD | 130mm 6-Bolt INTL STD | 170mm 6-Bolt INTL STD
3964
http://www.chainreactioncycles.com/Images/Models/120/794.jpg
More Info
Magura Disc Magura Louise Vented Rotor
Enhanced ventilation disc with improved performance under extreme riding conditions. Features: ?Ventidisc: 15% enhanced ventilation thanks to the awesome looking vented spider. ?Improved performance under extreme riding conditions. Available in ....
In Stock Now: 160mm 6-Bolt - Red Spider | 203mm C-Lock - Red Spider | 203mm 6-Bolt - Black Spider | 160mm 6-Bolt - Black Spider | 180mm 6-Bolt - Black Spider | 160mm C-Lock - Black Spider | 180mm C-Lock - Black Spider | 203mm C-Lock - Black Spider
2529
385.89 ZARhttp://www.chainreactioncycles.com/Interface/Offers/Sale.gif
RRP 693.40 ZARSave 36%
http://www.chainreactioncycles.com/Images/Models/120/20750.jpg
More Info
Magura Disc Magura Marta SL
Replacement disc rotor for the Magura Disc brake system. International Standard 6-Bolt fitting
In Stock Now: 180mm 6-Bolt | 203mm 6-Bolt
2886
397.83 ZAR
RRP 624.06 ZARSave 27%
http://www.chainreactioncycles.com/Images/Models/120/1514.jpg
More Info
Magura Disc Magura SL Rotor
In 2006 Magura offer the SL rotors with diameters of 210, 190, 180, and 160mm. All of them come with 6 fitting holes and are compatible with the MAGURA Centerlock adaptor. Features: ? Wavy Design Rotor for better visual styling ? Features standa ....
2581
397.83 ZAR
http://www.chainreactioncycles.com/Images/Models/120/7631.jpg
More Info
Shimano Disc Deore RT61
Stainless steel 160mm Disc Rotor for use with the Deore Disc Brake, 6 mounting bolts included.
In Stock Now: 160mm 6-Bolt | 160mm 6-Bolt - FLOOD
897
96.47 ZARhttp://www.chainreactioncycles.com/Interface/Offers/SaleAndClearance.gif
RRP 207.88 ZARSave 47%
or
Shimano Disc Deore/LX/Hone RT62
The Center Lock system makes an easy rotor installation possible with a spline mount and lock ring. The lock ring mounting system enhances precision and rigidity while improving braking efficiency Features: ?Center lock system ?160mm/180/203mm s ....
In Stock Now: 160mm Splined with Lockring | 180mm Splined with Lockring
1238
168.71 ZAR
RRP 207.88 ZARSave 7%
I currently have Juicy 3.5's, compared to Deore I prefer the Deore (plus on paper Deore is lighter, not sure how factual this is). I have had a couple issues with my rear brake which probably has made me anti-Avid for life.
When CRC get stock I will be switching to XT.
