OK, so I'v finshed my build except for one thing!
I have a 'star nut' top cap to seal off the steerer tube and compress the whole assembly.
The nut is obviously a little bigger than the steerer tube, so how do i get the star nut into the tube??
Just hit it down???
Much appreciated
The easiest way is to take a screw driver that is small enough to fit in to the hole that the bolt screws into and just knock it in. It is quite easy to see if the star nut is going in straight aswell
Good luck
