I got a wireless speed sensor for my wireless powertap. I am going through the "learn" id process, but the cpu is not picking up the id. I repeated the steps for my HR strap and hub and both work fine and register the id, but not when I do the speed sensor. I have already flipped the small switch inside to speed. Help please!
You don't need spped sensor if you have powertap hub wheel. I use powertap hub wheel for training and speed sensor for racing.
Try remove your powertap hub away from CPU and speed sensor. It should pick up! Go to setup 5 and make sure, change from watts to speed.
