Hey hubbers
I have a single CS200 with speed and cadence sensors on two different bikes.
I have setup the two bike on the CS200.
How do I tell the CS200 which bike I'm on?
Hey hubbers
Hi GhostRider 2
Activate your polar by pressing the middle key. Press the Next button (Right Key) untill Settings show on your screen. Press the middle button (Start) once. Press the right button (next) untill you get to Bike Set. Press Middle button (Start). Ther will be a number (either 1 or 2 ) that will flicker. Press Set (Right) button to chose between bike 1 or 2. Press the middle button. It will show Autostart on/off and then Cadence On/off and then the wheel sizes. make your choice by pressing the right button (Set). Run through this untill it gets back to Bike 1/2. Press Back (Left button) untill you are back to the clock mode. Press left again and it will be put into standby mode.
Hope this help.
Thanks for taking the time to reply Burts.
So are you saying that once I get back to the Bike 1/2 screen, what ever bike I leave it on before pressing Back (left button), that is the bike that will be used in terms of the settings and recorded distance?
That is correct yes. Just switch through the wheelsize settings back to whichever bike you choose and you are set. To be honest... Polar could have done more to make you switch faster between 2 bikes. But that is only my humble opinion. :blink:
Edited by Burts
That is correct yes. Just switch through the wheelsize settings back to whichever bike you choose and you are set. To be honest... Polar could have done more to make you switch faster between 2 bikes. But that is only my humble opinion. :drool:
Thanks again.
I agree. They don't make it too clear in the manual either.
I'll give it a bash in the morning.
Edited by GhostRider2
