Hey guys, I can get this bad boy for R6000-00
Here's the specs (thinks is a good deal bang for buck scenario) FRAME Specialized M4SL fully manipulated alloy frame, fully butted, integrated HT, forged dropouts w/ replaceable derailleur hanger, disc only
FORK RockShox Recon Silver SL, magnesium lower, 1 1/8"" alloy steerer, 32mm Cr-Mo stanchions, coil spring w/ preload, external rebound adj. & LO
HEADSET Integrated 1-1/8"" threadless, Campy type full cartridge bearings
STEM 3D forged alloy, 7 degree rise, 31.8mm clamp
HANDLEBARS Butted alloy riserbar, 25mm rise, 8 degree back sweep, 6 degree up
TAPE / GRIPS Specialized Enduro, dual compound Kraton, no flange, 131mm
FRONT BRAKE Avid Juicy 3 SL hydraulic disc, alloy backed pads, 160mm G2 Clean Sweep Rotor
REAR BRAKE Avid Juicy 3 SL hydraulic disc, alloy backed pads, 160mm G2 Clean Sweep Rotor
BRAKE LEVERS Avid Juicy 3 SL hydraulic
FRONT DERAILLEUR Shimano Deore, 34.9mm clamp, top swing, dual pull
REAR DERAILLEUR Shimano SLX 9sp Shadow Long cage
SHIFT LEVERS Shimano SL-M590 Deore trigger
CASSETTE / FREEWHEEL Shimano HG50, 9-speed, 11-34t
CHAIN KMC X9L w/ reuseable Missing Link
CRANKSET Shimano FC-M521, Hollowtech, Octalink spline
CHAINRINGS 44A x 32S x 22S replaceable
BOTTOM BRACKET Shimano BB-ES25, Octalink spline, cartridge bearing, 68mm x 118mm
PEDALS Alloy 1pc. body and cage, reflector kit, 9/16
RIMS DT-Swiss 445, 26"", alloy double wall disc, pinned w/ eyelets
FRONT HUB Forged alloy, hi/low flange, double sealed, ground race, machined disc mount and flange, QR, 28h
REAR HUB Forged alloy, mid flange, double sealed, ground race, machined disc mount and flanges, cassette, QR, 32h
SPOKES 2mm (14g) stainless
FRONT TYRE Specialized The Captain Control, 26x2.0"", 60TPI, tubeless ready aramid bead
REAR TYRE Specialized The Captain Control, 26x2.0"", 60TPI, tubeless ready aramid bead
TUBES Presta valve
SADDLE Specialized Rockhopper XC, Body Geometry, 143mm width, front and rear bumpers
SEAT POST Alloy two bolt, 12.5mm offset, micro adjust, 30.9mm
SEAT BINDER Forged alloy QR, brass washer
NOTES Chain stay protector, reflectors, clear coat, owners manual
