Track 4 Africa on Garmin Edge 800
Merida002
Hi All,
Does anybody know if I can use the Tracks for Africa maps on a Garmin Edge 800, also does the routing work properly too? Thanks
Link to comment
Share on other sites
Yup, works fine - including the routing.
I found that it works best with t4a loaded to the sd card and not on the unit memory. Also remember to disable the base map once you have t4a loaded, otherwise the unit it seeing two map sets and does funny things.
Link to comment
Yup, works fine - including the routing. I found that it works best with t4a loaded to the sd card and not on the unit memory. Also remember to disable the base map once you have t4a loaded, otherwise the unit it seeing two map sets and does funny things.
Awesome, thanks I'll give it a try later.
Link to comment
