I have a 2010 Epic Comp carbon with a SLX (E-type) front derailer, which I would like to replace with a SRAM one - is there one that will work or do I have to stick to Shimano?
Tx!
Will get the specs and send them - one thing - on your current setup there is a "black bcking plate" on which the shimano derraleur fits - you have to remove this for the sram - easy just two bolts - if you are in a hurry give Kevin a shout at buycycle he knows which model you need - he helped me out when I did my build.
