Hi all
Dont know if this question has been asked before...
Can I run my 10 speed chain on my 9 speed cassette?
Any information will be nice.
Regards
Chain As you go to more sprockets on the cassette, you need a narrower chain. However, using a chain one size narrower than standard rarely presents any problem. Thus, you can use a "9-speed" chain with a 7-speed or 8-speed system, or a "10-speed" chain with a 9-speed system. This is not the ideal approach -- shifting may not be quite as smooth -- but it's workable.
Narrow chains bring other problems, though. They are usually more expensive and -- with 10 or more speeds -- don't last as long -- even when used in the intended system.
http://sheldonbrown.com/speeds.html
