HI. I managed to do a reset on my rider 40........ Don't ask me how. It was not intentional........ Some of my settings were not erased, and my ODO is back to Zero. That's all good, I'll start from Scratch....... But I cannot select between the Bike1 and Bike 2 options. It is stuck on Bike2. There is also no ID code for the Sensors (Code:0). Has anyone had this happen before? Will the coded sensors still be free of inteference? Is there any way I can Select between 2 Bike profiles?
EDIT- Typo
Edited by akneethling
you need to rescan the sensors in...if you cant switch between the 2 bikes then there is a problem, maybe do another reset?
I did rescan the sensors, and tested them after. They are working. But I am concerned that the coding could be out, then someone else using similar sensors could interfere with my readings.
