Hi guys I fitted a new slx rear derrailer, and noticed their is no barrel adjuster. Is their another way to adjust cable tension on the derrailer ? Or must I use the barrel at the shifter. Thanks
Use the barrel at the shifter. Counter clockwise would be to tighten
Thank you.
So its normal that the slx rear derailers do not come with barrel adjusters on the derailer ?
All newer derailers only come with adjuster at the shifter afaik. All my bikes only have an adjuster at the shifter
Ok great
