What is the difference if I use my current tyres with a tubeless conversion or if I use 'tubeless ready tyres' ?
You may just have all your sealant seep out through your sidewalls overnight. It depends on the tyre. Schwalbe non-tubeless-ready generally will hold up well.
Give it a whirl, you have nothing to lose but a bit of Stans! If it seeps at first, it may still seal up, after which just add a bit more Stans and ride.
You must use Stans of course. Nothing else will do.
And why wouldnt it seep it out through 'tubeless ready' sidewalls ? Thanks
Because they're thicker.
UST (certified) sidewalls are even thicker (and thus heavier), but can hold air and run without sealant; even though it's a silly thing to do because there is nothing to stop deflation in case of a puncture.
