I want to change the SCOTT DT Nude2 rear shock on my 2013 model Scott Spark 940 to a FOX. I understand that I need a shock that is 165 mm long, but apparantly I also need a secial size washers to make the shock fit.
Has anyone done this change or can anyone offer some advice?
Thank you.
Eddie
I did the conversion on my Spark 900RC earlier this year.
Installed the top of the range Fox Float CTD Kashima manual with trail adjust. Man what a difference!!!
The remote one works with the twinlock lever but is very stiff. The manual has the 3 additional trail adjust settings which work well for fine tuning. I now actually never lock or unlock the shock..........just leave it in trail and forget about it!
When you order just ask for mounting hardware for a spark and they will supply the correct bushes.
Thank you very much for the reply. Where did you ordered it from?
