I don't know, if you see the hip joint as the pivot point, then 5mm variance in crank length vs the variance of 100mm in Femur length seems trivial for different rider lengths. The taller guy would normally also have longer feet, that displaces his ancle joint (the other pivot) further away from the pedal center point.
