http://www.light-bikes.com/BikePhotos/Road/Gunter_Mai.jpg
Model:SPIN CustomWeight
Bar Tape: Veloplast (only on the top of the bars)12
Bottom Bracket: THM (weight incl. in Crankset)0
Brake Levers: Campagnolo Record modified87
Rear Brakes: AX-Lightness Orion modified89
Front Brakes: AX-Lightness Orion modified (weight incl. in Brakes rear)0
Cables:PowerCordz cables, 4.5mm pneumatic hose for housing16
Cassette:Recon Alu block 11-16 6speed, 11T sprocket steel - modified53
Chain: KMC X10SL Silver215
Crankset: THM367
--Arms: THM0
--Ring bolts: Tune9
--Outer Ring: Aluminum modified 50T69
--Inner Ring: Carbon 36T (weight incl. in Outer Ring)0
Derlr (Front)Campagnolo Record / BTP29
Derlr (Rear)Sachs Huret, customized w/ CF parts- BTP48
Fork:THM custom Scapula SP Tuned214
Frame: SPIN Custom678
Handlebar: Schmolke Custom TLO 400mm111
Headset: Custom integrated27
Headset Cap/Bolt:0
Pedals: Aerolite Titan modified65
Quick Releases:Tune Skyline modified16
Seat Binder: BTP Carbon6
Seat: Tune Speedneedle (saddle/seatpost combination - weight incl. seat post)77
Seatpost: Schmolke (saddle/seatpost combination - weight incl. in Seat)0
Shifters: BTP carbon downtube shifters9
Stem: Nordischer Rahmenbau Custom Carbon 110mm54
Tire (Front)Tufo Elite 110109
Tire (Rear):Tufo Elite 110111
Tubes:0
Wheelset (Front):0
Wheelset (Rear):0
Wheelset:Lew Pro VT-1 Custom Boron - modified704
Misc Option: Air/Glue20
TOTALS:
grams:
3195
pounds:
7.04
http://www.light-bikes.com/BikePhotos/MTB/heinz_scott_mtb.jpg
Model:Scott Scale LTDWeight
Bottom Bracket: Fly Sports incl.0
Brake Levers: Extralite Carbon tuned52
Rear Brakes: Steinbach with Tune Pads68
Front Brakes: Steinbach with Tune Pads66
Cables:Power-cordz / Tune Plastik-stuff57
Cassette:Carbon 11-2762
Chain: KCM 10SL216
Crankset: 0
--Arms: FlySports Propeller incl. BB and Bolts344
--Ring bolts: Extralite8
--Outer Ring: MGM Carbon 44 X 9430
--Middle Ring: MGM Carbon 29 X 9412
Derlr (Front)B-T-P Capmpa66
Derlr (Rear)B-T-P Carbon99
Fork:SID Extrem (Carbon inside) Evo II776
Frame: Scott Scale LTD Size L1033
Grips:Custom3
Handlebar: Custom Carbon Combo110
Headset: Extralite Scalehead45
Headset Cap/Bolt:Schmolke Carbon4
Headset Spacer:Carbon4
Pedals: M2 racer ORB 290
Quick Releases:Tune Skyline MTB17
Seat Binder: B-T-P Barbon6
Seat: M2 Racer42
Seatpost: Schmolke TLO w. Shim105
Shifters: Sun tuned83
Stem: incl0
Tire (Front)Maxxlite 310297
Tire (Rear):Maxxlite 310300
Tubes:Notubes Kit with 30 ml78
Wheelset (Front):0
Wheelset (Rear):0
Wheelset:0
--Rims: NoTubes 28H- Custom made607
--Spokes: Bladed Titan v 28X1,8 / h 14X1,8+14X2,2200
--Nipples: DT16
--Front Hub: Extralite Ultrahub SPD45
--Rear Hub: Extralite Ultrahub SPD149
TOTALS:
grams:
5090
pounds:
11.22
http://www.light-bikes.com/BikePhotos/MTB/lenz_ls.jpg
Model:LITESPEED SEWANEE CUSTOMWeight
Bottom Bracket: THM incl.0
Brake Levers: Extralite Custom52
Rear Brakes: Steinbach with Corima69
Front Brakes: Steinbach with Corima71
Cables:Powercordz with Tune 5/6mm65
Cassette:Tune Rasselbande Proto 11-26 incl. Edelzwicker93
Chain: KMC 10 SL216
Crankset: THM CLAVICULA DP Proto365
--Ring bolts: Ta8
--Outer Ring: TUNE Coalfiber29
--Middle Ring: TUNE Coalfiber18
Derlr (Front)CAMPA BTP with Coalfiber63
Derlr (Rear)Tiso Tuned134
Fork:Rock Shox Sid AS Tuned865
Rear Shock: German Answer158
Frame: Litespeed Sewanee Custom1742
Grips:No Name3
Handlebar: Schmolke TLO49
Headset: TUNE BOBO Proto52
Headset Cap/Bolt:TUNE Verh?terli6
Pedals: Eggbeater 4ti165
Quick Releases:Tune Skyline17
Seat Binder: Tune Skyline5
Seat: TUNE Skyline incl.0
Seatpost: TUNE Skyline121
Shifters: Sachs Tuned83
Stem: Syntace with Titanbolts85
Tire (Front)Maxxis Maxxlite302
Tire (Rear):Maxxis Maxxlite301
Tubes:Notubes System72
Wheelset (Front):0
Wheelset (Rear):0
Wheelset:TUNE Skyline with MIG 30 and MAG 140 with1072
--Rims: Fullceramicbearings an Notubes 32/320
TOTALS:
grams:
6281
pounds:
13.85
