29er wheels & hub Specialized Rumor 2014
washaw70
Hi,
I wonder if you can help. I would like to get another set of wheels or my wife's 2014 Rumor (spare set for road work not an upgrade for weight) , I have found a set of epic comp 2014 wheel. The dealer is telling me it wont work because it is a 142 +(plus) width hub and the Rumor has 142. Is there a possible solution out there ?
thanks
warren
They will work, It will just be a case of adjusting the brakes and gears every time you change the wheels...
Basically the plus hub means they have moved the rotor out by +- 3mm and the cassette by +-4mm so its not huge...like I say they will fit but just some adjustments will be needed.
