What will fit my silverback
mulmi
Think you've got the model wrong, it can be a Sola4 (2014/2015) or Vida4 (2012/2013). In 2011 I think the model was called Segma Two Nine.
Assuming that you have one of Silverbacks 29 inch Hardtail MTB models, I think its safe to say a 2.25 tire should fit perfectly (with sufficient mud clearance). Some frames have a problem fitting 2.4 wide tires, unless they specifically state they can fit the wider tires.
My wife has a 2014 Sola4 and there is more than enough clearance to go fromt he 2.1 inch wide maxis to possibly 2.3 inch wide tires.
