Giant Xtc Advanced frame serial number help
GRG
Bike was stolen and I have two possible frame serial numbers, but not sure which one is the correct one. Anyone who could advise or who has the same make and model to check serial number resemblance, please help! According to me the frame is a 2012 frame, but the website says its 2013. The reason I say so is that the FAQ section on the website states that the 3rd digit of the serial number is the year the frame was manufactured. The numbers are: GL2V3132 and EN14766.
See attached image of bike.
Where did you hear that ? I have a 2014 Giant none of the two numbers under the bike have a 4 in them though never mind it been the 3rd digit, if i remember when I registered the bike on Giants Warranty website i used the "serial" that started with G
      Surveillance (SGS):     European Standard EN 14766     Product: CHANGE DF-5 Folding Frame
Test Clauses
 EN 14766 Euro MTB
Test Method
Result
4.8.2
Frame and Front Fork Assembly-Impact Test (Falling Mass)
22.5kg Striker, Drop Height 360mm
Pass
4.8.3
Frame and Front-Fork AssemblyàImpact Test (Falling Frame)
80kg Mass, 300m Drop Height
Pass
4.8.4
Fatigue Test with Pedaling Forces
Downward Force 1,200N, 100,000 Test Cycles
Pass
4.8.5
Fatigue Test with Horizontal Forces
Force +1200N -600N, 50,000 Test Cycles
Pass
4.8.6
Fatigue Test with a Vertical Forces
Vertical Downward Force 1,200N, 50,000 Test Cycles
Pass
