flat29 Posted March 12, 2015 Posted March 12, 2015 Good day all I am currently on a specialized stumpy HT carbon and looking at my next bike. I want to use the new bike for marathon riding (not a race snake) and stage racing. I have been looking at the Spez camber comp carbon and found the Cube Stereo 120 HPC The Camber price R 43 999 and the cube R 37 000 Both has front triangle carbon with rear alu Camber 110mm travel and cube 120mm travel. I know that the cube comes with a standard xt Rd but for R7000 less I can change that to the XT RD with clutch and change the 3x10 to 2x10 My question to all the hubbers: What do you think of the cube? http://www.cube.eu/en/bikes/fullsuspension/stereo/cube-stereo-120-hpc-pro-29-black-grey-green-2015/ FRAME HPC Carbon Monocoque Advanced Twin Mold Technology, Aluminum 6061 T6 rear triangle, ARG, ETC 4-Link, AXHCOLOR black´n´grey´n´greenSIZE 16", 18", 20", 22"FORK Rock Shox Reba RL 29 Fast Black, PushLoc, 15QR Maxle, tapered, 120mmREAR SHOCK Fox Float CTD, 200x51mm, Climb/Trail/Descend mode, LV air canisterREAR SHOCK HARDWARE top: 30x8mm, bottom: 22x8mmHEADSET CUBE I-t integrated, top 1 1/8", bottom 1 1/2"STEM CUBE Performance Pro, 6°HANDLEBAR CUBE Flat Race Bar Pro, 720mm, 8°GRIPS CUBE Race Grip, 1-clampREAR DERAILLEUR Shimano XT, RD-M781-DSGSL, Shadow 10-Speed, direct mountFRONT DERAILLEUR Shimano XT, FD-M781-A, direct mount, 3x10-speedSHIFTERS Shimano XT SL-M780-I, Direct AttachBRAKE SYSTEM Shimano XT K-M785 Hydr. Disc Brake (180/180)CRANKSET Shimano XT, FC-M782, 40x30x22T, 175mm (180mm for largest frame size)CASSETTE Shimano XT CS-M771, 11-36CHAIN Shimano XT CN-HG95WHEELSET Fulcrum Red66 15QR/X12, 622x19CTIRES Schwalbe Nobby Nic Kevlar 2.25, Tubeless EasySADDLE Selle Italia SC1SEAT POST Rock Shox Reverb Stealth 31.6mm, 125mm adjustable seatpost, internal routingSEATCLAMP CUBE Screwlock 34.9mmWEIGHT 12,85 kg
flat29 Posted March 12, 2015 Author Posted March 12, 2015 Camber FRAMEFACT 9m carbon front triangle, 29" geometry, FACT IS construction, M5 alloy rear triangle, tapered headtube, carbon PF30 BB, full internal cable routing, 142mm dropouts, sealed cartridge bearing pivots, replaceable derailleur hanger, 110mm travelREAR SHOCKCustom FOX Float CTD Evolution w/ AUTOSAG, air spring, lockout, rebound adjust, 197x48mmFORKFOX Float CTD Evolution 29, air spring, tapered steerer, Climb, Trail, Descend settings and rebound adjust, 15mm thru-axle, 110mm travelHEADSET1-1/8 and 1-1/2" threadless, Hella Flush style upper with 1-1/2" lower, cartridge bearingsSTEMSpecialized XC, 3D forged alloy, 4-bolt, 6-degree riseHANDLEBARSSpecialized XC, mini rise, 6000 butted alloy, 8-degree backsweep, 6-degree upsweep, 10mm rise, 31.8mmGRIPSSpecialized Sip Grip, light lock-on, half-waffle, S/M: regular thickness, Others: XLFRONT BRAKEShimano Deore BR-M506, hydraulic disc, dual piston, resin pads, S/M: 180mm rotor, Others: 200mmREAR BRAKEShimano Deore BR-M506, hydraulic disc, dual piston, resin pads, S/M: 160mm rotor, Others: 180mmBRAKE LEVERSShimano Deore BL-M506, hydraulic, alloy leverFRONT DERAILLEURSRAM X7, 10-speed, S3 direct mount for DMD, bottom pullREAR DERAILLEURShimano XT Shadow Plus, 10-speed, SGS long cageSHIFT LEVERSShimano SLX, 10-speed, triggerCASSETTESRAM PG 1030, 10-speed, 11-36CHAINSRAM PC 1031, 10-speed, w/ PowerLink, nickel finishCRANKSETCustom SRAM S-1250, 7050 alloy arms, 10-speed AM double, PF30 spindle, 36/22, 104/64mm BCD spiderBOTTOM BRACKETSRAM, PF30, OS press-in bearings, sealed cartridgePEDALSResin test ride, w/ toe clips, CEN std.RIMSRoval 29, alloy, 21mm inner width, 32hFRONT HUBSpecialized Hi Lo disc, sealed cartridge bearings, 15mm thru-axle, 32hREAR HUBSpecialized Hi Lo disc, 4 sealed cartridge bearings, 12mm thru-axle, 32hSPOKESDT Swiss Industry, stainlessFRONT TIRESpecialized Ground Control, 60TPI, 2Bliss Ready, folding bead, 29x2.3"REAR TIRESpecialized Ground Control, 60TPI, 2Bliss Ready, folding bead, 29x2.1"SADDLEBody Geometry Henge Comp, hollow Cr-Mo rails, 143mmSEATPOSTSpecialized alloy, single bolt, 30.9mmSEAT BINDERSpecialized 7050 alloy, single bolt, 34.9mm
Cat2forLife Posted March 12, 2015 Posted March 12, 2015 That Cube is damn sexy..Go for that! Then you wouldn't have to be seen on a Spaz
RockCoach Posted March 12, 2015 Posted March 12, 2015 The Cube FTW. I rode one briefly and was very impressed.
flat29 Posted March 12, 2015 Author Posted March 12, 2015 The cube is hot. Thanks for your info hubbers
Guest Posted March 12, 2015 Posted March 12, 2015 http://enduro-mtb.com/en/preview-group-test-seven-low-travel-trailbikes-for-tours-and-adventures/
flat29 Posted March 12, 2015 Author Posted March 12, 2015 The Cube FTW. I rode one briefly and was very impressed.did you ride the one at eldron?
RockCoach Posted March 12, 2015 Posted March 12, 2015 did you ride the one at eldron?No the demo which was at my shop.
