Ride Light Wiring- Help please
facepalm
My ride light had shorting issues and it turns out a connection had come loose in the factory moulded junction joint. In disassembling the joint I lost track of the wiring. Please help me match the numbers in the picture attached. 1 Brown 2 Blue 3 Red 4 Black 5 White 6 White 7 Blue 8 Black 9 Brown
Have you got a multimeter to measure continuity on the switch? Youll have to see which of 3,4,5 is the common on the switch.
The common will go on the positive of the battery.
The light also has a common which will be connected to the negative of the battery.
I think youll only have 2 of the lights 3 functions I THINK, I COULD BE WRONG
Trap diep
Trap diep
Thanks Mop, will check tonight and let you know.- I do have a multimeter
