Suspension bearings on Specialized ERA
BFG
Hi all. I hope there is someone out there who can assist me. My wife rides a 2012 Spesialized ERA comp. The bearings on the rocker arm (i think ) see photo, was destroyed. I need the bearing numbers of the bearings that go in there. The ones that connect the rear triangle are 6888. The ones that connect to the shock....mince. Thanx.
The ones that are toast - you need to get the remaining part of the race out.  That will give you the OD and the width of the bearing.  The bolt that goes through it in will give you the ID. Use those measurements to spec the new ones.  The other may be a 688 (I haven't heard of a 6888) I would take all parts to a bearing shop and they will be able measure for you.
