Scott twinlock and rockshox sid set up.
Sharkcatcher01
Hi.
I am busy building a Scott spark with a rockshox sid that has a remote lockout.
Problem is on the twinlock when the rear shock is locked out the front is open, and visa versa.
Any idea how I can fix this other than using the rockshox remote lockout?
Hi.
There are two barrel adjuster on the twin lock one for the front and one for the rear shock on the first click turn the adjustet out until the front shock lock out on the second click turn the adjuster until the rear lock out one click back will unlock the rear shock click back to unlock the front shock hope it will help some rear shock are not design to fully lock out they will stiffed the suspension just Google twin lock there are some good info how to setup the twin lock
Your problem is the fork - the newer RS forks have a lockout that works backwards. A prize brainfart from the RS design team...
Two possible solutions - either send the shock off for a service and specify that they switch the lockout to work the other way, or replace the fork damper with the pre-2013 version that works the right way around.
