Rear shock swop Anthem to KTM Scarp Prime
Gregc
I have an option to buy a KTM Scarp Prime carbon full Sus frame.
The eye to eye measurement for the rear shock  on the Scarp frame is 175mm and on the Anthem 165mm.
Can i use the same rear shock from the Anthem on the Scarp or will i need to replace
The current rear shock on the Anthem is a Rockshoc Monarch RT as was on the bike when i purchased it new 3 years ago
Any advice/comments please
No it won't work. The leverage ratios of the linkages differ, hence the different eye to eye lengths.
Don't buy a frame without a shock. Every frame has a shock tune that works with it, and if you slap in a different shock, it won't work as the designers intended.
Its a warranty replacement with only the mount for the front derailleur that i cracked. Getting at a good price except no shock.
Spec sheet says it comes with a Fox Float CTD Boost valve W3 but cant find it on the Fox website
