CODA rear hub
Oubaas
post-93331-0-35889100-1461070704_thumb.jpgHi, hope you can help. My CODA rear hub on yellow anodized open pro rim laced semi-radially, needs to be replaced. Wheels came out late 1990's. Would like to replace hub with CODA but will a alternative hub fit and what will do the job? Thx.
CODA hubs are a Cannondale label.  I think most were made by DT Swiss but there could have been some other manufacturers as well.  If yours dates from the 1990's I doubt that you will replace it easily - that said you will probably want to replace the spokes as well so you can use any other hub with the same number of spoke holes.  How many holes does yours have?
Thx for the reply. 28 holes. And I was fortunate to find someone in Jhb who still have a old one witch I can have.
