I bought a 17" Raleigh RM 6.0 in November 2006.  Two weeks ago I cracked the frame (after 8100km), so Raleigh is now replacing it with the 2008 RM 6.0 frame.
Problem is that the 2007 models came in the sizes 15", 17", 19" and 21".  The 2008 models come in 16", 18" and 20".
Which 2008 frame size will be the correct one to replace my 17" frame with?  I can only find the geometry info on the 2008 models, so I can't do the comparison myself.
The 17" was already slightly small, so I would prefer to go one inch up rather than going smaller.
In 2006 there was not an RM 6.0 model yet' date=' so I assume that you had an RM5.0?
You know how it is with bicycles:  The next years models get released by the end of the year.  So, in November 2006 the 2007 Raleighs were released.
I don't know what the logic is behind it.  So, I do have a RM6.0.
Here is the geometry info for the 2007 RM6.0:
XS S M L
Frame Size C-T 381mm (15") 432mm (17") 438mm (19") 533mm (21")
Head Angle   71 71 71 71
Seat Angle   73 73 73 73
Top Tube   555mm 575mm 605mm 620mm
Chain Stay   425mm 425mm 425mm 425mm
Headtube   120mm 120mm 130mm 140mm
BB height   35mm 35mm 35mm 35mm
Wheel Base   1038mm 1058mm 1088mm 1103,5mm
Fork Travel   80mm 80mm 80mm 80mm
http://www.raleigh.co.za/UserFiles/Image/rm6_rm4.gif
And here is the geometry info for the 2008 RM6.0:
S (16") M (18") L (20")
Frame Size C-T 41cm 46cm 51cm
Head Angle A 71 71 71
Seat Angle B 72.5 72.5 73.5
Effective Top Tube C 57cm 58cm 60cm
Chain Stay D 425mm 425mm 425mm
Wheel Base E 1038mm 1049mm 1080mm
BB Drop F 35mm 35mm 35mm
Headtube G 120mm 125mm 145mm
