Going tubeless
Guest ToxicD
  On 1/23/2017 at 1:22 PM, ToxicD said:
Or neither if you choose your tires meticulously.
Bearing in mind nothing lasts forever. Throwing your bike off a building also ensures you wont ride soon
What puncture proof tyres are you riding on then?
Not to sure if you are being serious now or ...
If you were being technical then none cause I didn't put a solid piece of rubber on the rim.
If you understand how tubeless work (I assume you do with your post count so you have been around) then I opted for the not so heavy IKONS (around 200g less than the Crossmark per tire) as I dont need the durability of Crossmarks because I dont tend to ride my bike in extreme conditions where it is needed.
