Abnormal Cassette wear??
Dominik Krob
Hi fellow Hubbers!
So as i follow my weekly routine of giving my beloved bike a scrub today, I noticed what I perceived as abnormal cassette wear, unless I'm just imagining things...- so that's where you guys come in: the photo in this post shows my cassette. The larger cogs seems to have the chain profile imprinted. This can't be normal? Some additional info that may be important. I am running a campy chorus 11 (2014) drivetrain, chorus cassette (11-29), cassette is only about 2000km (!!) old, chain is KMC X11-93 silver, installed new same time as cassette. This is the first time I have paired a KMC chain with my campy drivetrain, thought I'd give them a try as I've only heard good things...; never noticed this type of wear pattern, especially after such short time, with campy cassette/ campy chain combination.
Oh in case you guys wonder: drive train thoroughly cleaned every 1-2 weeks, and adequately (in my opinion) lubricated with dry lube.
Thanks guys!!
just my opinion...that cassette is toast so is the chain :blink:
why?..
maybe your derailleur has too high a tension or your derailleur hanger may be bent, causing the chain to ride a little too close to the next largest cog either way its kaput
(some kmc chains are a tiny bit wider than other makes and im sure if that's the case it didn't help )
id take your bike to a campy experienced mac and let him look before you fit new kit and then let him set it up after you do (or he does)
and for a road bike you are washing your drive train too much mate (not that that caused the damage but still)
sorry to be the bad news fairy :huh:
why?..
Eish I thought this would be the case...
Any recommendations re capable campy mechanics? I know Finish Line cycles has a good reputation here in Jozi but I've had my derailleur hanger replaced there around the same time I replaced my cassette and chain. They would've looked at tuning etc...
why are you replacing your hanger was it damaged or bent ?
not good
questions ..(as it appears the hanger repair occurred when this cassette and chain where replaced so they are possibly related )
did they put a new hanger on or did they straighten the old one maybe? (just asking not accusing )
...do you know the hanger is actually straight?
did they fit it correctly (as in did they correctly check its alignment with a tool considering a bent hanger means bent screw holes, bent screws ,possible damage on frame etc)
why was it bent ? if you have a prang or a dropped bike ...is your frame bent a bit maybe ?
stick a question for a good campy mac up on forums im not in jozi so I cant recommend
not good
- The hanger was replaced with a new part
- no, can’t say for sure that the hanger is straight. I like to do a lot of work around the bike myself but I don’t have the tools to verify hanger alignment and such.
- I assume that the hanger was fitted correctly, but again I can’t say for sure. I guess this would be more reason to have the fitment verified by a reputable 3rd party.
- I bought the frame second hand so it may be prior damage. I noticed misalignment when in the big ring/ > 21 cog as the bottom jockey wheel didn’t seem to be perfectly centered under the cog.
Thanks for all the advice, really priceless!
Just as a side note: I ran a 11-25 cassette (+/-5000km of use) with a reasonably new campy 11 chain and the bent hanger for a good 2000km with no abnormal wear.
tension adjustment on the RD may have changed with new cassette and chain (different mac sets it different and the tension affects cassette wear )
and a slightly wider than std chain (not a bad thing normally but an added problem in this scenario) ......
could explain why it didn't show with old 11-25 setup
id still get the hanger checked with an alignment tool though
sorry mate :wacko:
you should change it soonest before it eats your chainrings
sorry mate :wacko:
Thanks for all your advice. Will have the entire setup incl hanger alignment looked at this coming week. [emoji1303]
just me, but I don't bother with what the chain-ring looks like unless you have issues with gearshifts...  i managed to clock thousands of KM's on every cassette / chain pairing that i've ever done and had very few issues so far.  lube your chain, do the cleaning / maintenance you've been doing and keep on riding.
Only difference with me is I don't do dry lube.  wet lube all the way on MTB and road bike.  I don't care too much about the so called "grinding paste", as long as the chain runs quiet i'm happy.
