Trek Fuel 9.8 SL Questions
MudLark
What pressure are you running in the shock? Is it the Fox shock? Haven't got mine dialled in properly yet and think I'm probably running it a bit hard. I'm around your weight.
120 Rear & 75 Front.
Sorry, both Fox.
so I set it up approximately right last night
The annoyingly simple advice you always get on this forum - get a proper bike setup done by a pro.  It will feel like an even more capable bike
I have the Top Fuel and love it.  The first thing you notice is its superior climbing ability.  Agree about the twitchyness downhill, once my XR2 are done I may switch to something a bit more grippy.
Thanks for that.
I said "approximately" because the pro setup is being done tomorrow morning. :-)
Gotcha on tyres. Off they go then to be replaced by something else.
  • 2 weeks later...
Re the Re:Aktiv shock and its disappearance, early reports from Trek dealers seem to indicate that they are finding the 2019 model with the Fox DPS doesn't make as efficient a platform as the 2018 model with the Re:Aktive shock. There's also some talk about Fox developing its own proprietary design to replace the Re:Aktive. My take is something has happened around royalties or license fees payable to Penske or something similar.
