Valve size
Moooving
Howzit guys
I need some advice here please. I have bought myself a Zipp 404 front wheel and a Zipp 808 rear wheel.
What size valve must i get for each one? Ive been told i need to buy a valve extension for the 808, so do i buy 80mm or what what will work for both?
Thanks in advance
Long valve tubes can be pricey and not always stocked.
40-60mm tubes with extenders for front and rear.?
Also get removable core tubes with the appropriate extenders - they work better.
Thanks man so if i get 60mm tubes (Continental have removable core ones) then which size extension valves do i get? Looking on Chris Willemse Cycles they have options of 30mm, 40mm, 60mm. Thanks for your help.
