Shimano road 11speed derailleur with 36t casette
NGM
should work just fine, and if you run into issues you should be able to tighten up the B-screw tension to fix it. You can also usually open up the spring 'knuckle' and set the spring in the higher tension position to gain a mm or 2 clearance if needed.
I've only run into trouble when I tried to fit an 11-40.
