Hi All,
I have a 2017 S-Works disc with the early generation Shimano BR-RS805 brake calipers.
I want to replace the calipers but believe that the newer flat mount calipers will not work with my frame. Can you guys let me know which calipers I could buy to replace these?
Would appreciate any guidance!
Why do you want to replace the calipers - are you experiencing performance issues? Or is it a new frame?
They are a bit corroded and don’t seem to be functioning 100% all the time.
Its a mission to go this way. I went the other way. I used the calipers i had from my RS 805 calipers on my new levers so i can't comment accurately but i got adapters to do that i.e fit to the newer frame. I am sure that the calipers would have an adapter.
