For those lucky people with a Garmin Edge, I see there is a firware update available. Get it with the Webupdater.
Changes from version 2.40 to version 2.50:
Implemented change to allow the user to access Map Setup option for tracks which will allow showing that track on a map, and what color to display it in.
Added ability to set Off-Route Recalculation behavior in Routing menu. User can set it to Automatic, Off, or Prompted.
Fixed issue with long routes shutting down.
Fixed issue where Autopause and Start/Stop were not getting saved into the History files. This could also cause Courses created from this History to not register these times.
Fixed issue where History files would occasionally not upload due to misaligned data.
Fixed inaccurate elevation when moving to and from areas with distinctly different altitudes or atmospheric pressures.
Fixed random elevation spike in the first few track points.
Added the ability to delete tracks.
Fixed issue where speed would drop to 0 going through turns.
Fixed issue where viewing a Course on a map went to the wrong location.
Fixed barometer initialization issues in situations where the unit is turned off and back on within 5 minutes in the same location.
Fixed issue with Course List where actions could be applied to the wrong Course.
Fixed issue where course guidance lines were drawn on top of roads.
Fixed issue with repeated Autopausing when using a wheel sensor.
Fixed issue with creating a Workout with Spanish language selected.
Improved German translations.
  • Fixed barometer initialization issues in situations where the unit is turned off and back on within 5 minutes in the same location.
I've only experienced this issue so far.
I think I'll wait to see what this firmware version breaks before I upgrade Wink
