Hi Guys,
just for intrest sake, do you know what your frame and fork weighs?
I just serviced my Fuji Marseile pro, and weighed the frame with a cannondale ultra slice fork. Weighed in at 4800 grams. I thought it would be a bit lighter, but the stuff never weighs what the manufacturers say it wieghs.
Cheers
The lightest available is the Ghisallio(?) I think at about 700g. I am sure at 4800g the bike had the cranks and bb, and derailleurs on? That's terribly heavy, my old Cannondale Caad4 frame weight is about 1400g and the fork about 500g, so say 2000g.
2004 Fuji Marseille
http://www.bikepedia.com/Images/link.png Link to this page
http://www.bikepedia.com/Images/mail.png E-mail this page
addthis_pub = 'bikepedia';
http://s9.addthis.com/button1-share.gif
< ="http://s7.add.com/js/152/add_widget.js" =text/>
Years this model was made:
Side by side comparison
Bicycle TypeRoad race & triathlon
Sugg Retail$1,969.00
Weight18.3
Sizes49cm, 52cm, 54cm, 56cm, 58cm, 61cm
ColorsWhite
Frame & Fork
Frame ConstructionTIG-welded
Frame Tubing MaterialX-Fusion Quaternary Aluminum/carbon stays
Fork Brand & ModelFuji Full Carbon
Fork MaterialCarbon fiber composite w/carbon fiber steerer, aero crown
Rear ShockNot applicable
Components
Component GroupShimano Ultegra
BrakesetShimano Ultegra dual pivot brakes, Shimano Ultegra STI Dual Control levers
Shift LeversShimano Ultegra STI Dual Control
Front DerailleurShimano Ultegra, bottom-pull/clamp-on 31.8mm
Rear DerailleurShimano Ultegra SS
CranksetFSA Gossamer, 39/53 teeth
PedalsNot included
Bottom BracketShimano BB-5500, 109.5mm spindle
BB Shell Width68mm English
Rear Cogs9-speed, 12 - 26 teeth
ChainShimano CN-HG73, 1/2 x 3/32"
SeatpostRitchey Comp, 27.2mm diameter
SaddleFuji Ultralight Racing titanium rails
HandlebarRitchey Pro 31.8
Handlebar ExtensionsNot applicable
Handlebar StemRitchey Pro 31.8
Headset1 1/8" integrated
Wheels
HubsFront: Ritchey Pro Road, Rear: Ritchey Zero System Pro Road
RimsFront: Ritchey Pro, Rear: Ritchey Zero Pro Road OCR, 24-hole/28-hole
Tires700 x 23c Hutchinson Reflex
Spoke BrandDT stainless steel, bladed
Spoke NipplesAluminum
Do you guys know about the bikepedia website?
Got these off their site. This is my first bike, so don't know if it is responsive or not. I spoke to a dude the other day and he said he doesn't like fuji, the frames are not stiff enough, he only ride Willier.
Do you guys know anything about these fuji bikes?
Frames never weight what the manufacturer says it weights because they never define exactly what they are weighing, ....well save for Litespeed and Cannondale.
Cannondale gives you the weight of a frame and fork with uncut steerer and incl the derailleur hanger, and seat collar.
Litespeed Gisallo comes with CoC that confirms frame weight minus bolts.
Scott excludes the weight of bolt, derailleur hanger, bottle cgae bolts, ie ligtest possible configuration, not as sold.
Many companies do this. I weight is your thing then weigh the final bike and don't use the brochure as a bible.
trek 1500 58cm
Frame/headset and fork - 2kg (incl derailleur hanger/seat collar/steerer/water cage bolts)
Weighed it when I bought the frame.
I am Very happy - not worried about the weight (since its not the lightest,  but its sure is solid)
