Hi guys,
I was just wondering about the (seemingly high) price for this bike...is it reasonable?? Thanks so much :)
Online Status: Offline
Quote tahierp Replybullet Topic: 2008 Specialized S-Works Full Carbon Mnt Bike
    Posted: 2009 Apr 27 at 9:32pm
2008 Specialized S-Works Stump Jumper full carbon dual suspension mountain bike for sale. Size Medium.<?: prefix = o ns = "urn:schemas-microsoft-com:office:office" /><?: PREFIX = O />
Mint condition.
 Price R33000
  • Juicy Five Brakes
  • S Ram x9 Shifters
  • S Ram x9 rear derailers
  • XTR front derailers
  • DT Swiss Specialized rims
  • Bontrager Revolt Super X tubeless tyres
  • Carbon Fact Brain font shock120 mm travel
  • Brain rear shock
  • Evolve XC handlebar & stem
  • Thomson Seatpost
  • Specialized seat
Contact Tahier Phillips on 082 557 8336 or email on tahierp@iburst.co.za
http://www.specialized.com/us/en/bc/_img/store/icn_enlarge.gifEnlarge in
Gloss Carbon/Red
2008 S-Works Mountain Models
http://www.specialized.com/sp.gif
S-Works Epic
S-Works Epic Frame
S-Works Carbon HT Disc
S-Works Carbon HT Frame
S-Works M5 HT Frame
S-Works Safire
S-Works Safire Frameset
http://www.specialized.com/us/en/bc/_img/global/selectindicator.gif S-Works Stumpjumper FSR
S-Works Stumpjumper FSR Frameset
S-Works Enduro SL Carbon
S-Works Enduro SL Carbon Frameset
Other 2008 bikes
XC Trail
THE BEST GETS BETTER. With an all-new chassis design that is lighter,
more efficient, features a lower stand-over height and the same
incredible handling, the completely redesigned Stumpjumper FSR?
continues to be best bike for the trails most of us ride, most of the
time.
Inside Tech
The completely redesigned Stumjumper FSR
chassis features an ultra-refined and focused design, one that's been
completely integrated with critical suspension components. The top-tube
of the new Stumpjumper FSR sweeps down to ensure maximum standover
height and boost overall rigidity.
Useful Links
Total Suspension Integration
FACT Carbon
Suspension Setup
Roval Wheels
Manuals/Tech Bulletins
http://www.specialized.com/us/en/bc/_img/global/1x1.gif
  • S-Works
    FSR FACT 10M carbon main triangle frame, Az1 construction, M5 alloy
    rear triangle, full cartridge bearing pivots and rear shock mount,
    Magnesium shock link, carbon reservoir mount, 120mm travel
  • Specialized AFR Shock w/ Flow Control valve and Brain fade adjust shock
  • Specialized Future Shock S120, 120mm, Trail Tune inertia valve and adjustable Brain Fade
  • Specialized stands behind the materials and workmanship of any Specialized branded fork or rear shock for a full 5 years.
  • Magura Marta SL brakes, carbon lever, hydraulic disc
  • SRAM X.0, 9-speed, rear derailleur
  • SRAM X.0, carbon/aluminum trigger shifters
  • Roval Controle XC wheels
FRAME
All
new S-Works Stumpjumper FSR FACT 10m carbon main triangle, Az1
construction, M5 alloy chainstays with Brain mount, FACT 10m carbon
seatstays with carbon drive side dropout, DMD Direct Mount F.Der, full
cartridge bearing pivots, 120mm travel
REAR SHOCK
Specialized AFR Shock w/ remote Trail Tune inertia valve, adj rebound and Brain Fade, 7.25x1.75"
FORK
Specialized
Future Shock S120, 120mm travel, carbon 1 1/8 to 1.5" steerer, Trail
Tune inertia valve, adjustable Brain Fade and rebound, piggyback one
sided air spring and damper
HEADSET
1 1/8" threadless, Campy spec integrated sealed cartridge bearing
STEM
Thomson CNC alloy, 31.8mm clamp, 5 degree
HANDLEBARS
Specialized OS XC low rise carbon bar, 640mm wide, 6 degree up, 8 degree backsweep
TAPE/GRIPS
Specialized thin lock on grip, dual density
FRONT BRAKE
Magura Marta SL, carbon lever, hydraulic disc, 185 and 203mm SL rotor
REAR BRAKE
Magura Marta SL, carbon lever, hydraulic disc, 160 and 185mm SL rotor
BRAKE LEVERS
FRONT DERAILLEUR
Shimano M970 XTR, DMD top swing
REAR DERAILLEUR
SRAM X-0, 9-speed, mid cage
SHIFT LEVERS
SRAM X-0, carbon/aluminum 9-speed trigger
CASSETTE FREEWHEEL
Shimano XTR, 9-speed, 11-34t
CHAIN
Shimano 7701 XTR
CRANKSET
Shimano M-970 XTR
CHAINRINGS
Shimano XTR 22A/32C/44A
BOTTOM BRACKET
Shimano M-970 XTR
PEDALS
N/A
RIMS
Roval Controle, XC race, disc, 24mm
FRONT HUB
Roval Contr?le XC race, disc, straight pull
REAR HUB
SPOKES
Roval Contr?le, straight pull, alloy nipples by DT Swiss
FRONT TIRE
S-Works The Captain 26x2.0", 120 TPI, tubeless ready aramid bead, dual compound
REAR TIRE
TUBES
Specialized Ultralite, .6mm, presta
SADDLE
Specialized Phenom, Titanium rails
SEAT POST
Thomson straight w/ 12 degree clamp, 367/410mm
SEAT BINDER
Alloy collar w/ QR, 36.9mm clamp ID, for carbon frames
NOTES
Protective clear coat, derailleur hanger, reflectors, owners manual
Specifications subject to change without notice.
