I need to replace mt SLR front hub bearings My questions are:
Is this possible?
If so How does one go about doing this.
I have stripped the back SLR hub with no problems, but cannot seem to figure the front one out.
Is this a Crossmax SLR or Cosmic Carbon SLR?
You really should take it to your LBS that has a good mechanic. Mavic wheels use special bearings that have "play" built into them. If you use stock bearings you will ovalize the hub over time and have to buy a new hub/wheelset.
