Slide off the rubber cover and under it is the fine splined adaptor for Shimano Centre Lock Rotors, take both off if you are fitting the Centre Lock to 6 Bolt adaptor:
http://www.planet-x-bikes.co.za/images/products/Novatech%20centre%20lock%20to%206%20bolt%20adaptor.jpg
Thanks Wayne,
As per our P.M.'s I admit to the occasional bout of stupidity! Good job I didn't think 'don't need them' and threw them away then!
Just a question - why didn't Novatec just put the 'Shimano splines' on the Hub? Having different splines seems a bit pointless to me.
Cheers,
Dave.
There's obvously some 'patent' or 'royalty' issue no doubt - though are the splines that Novatec use not the same as the Shimano 'cassette' pattern? I would have thought that that had the same sort of issues (though SRAM use that, so maybe not!) - anyway, problem, solved, and very easy when you know!
Cheers,
Dave.
Hi Mampara,
The version we have only works with our wheels, I am finding out if there is a version that will fit Shimano Centre Lock hubs at the moment, I'll let you know.
