Hi. I cannot get information off the international website or from the local importers (they refer me to the website) about servicing this fork. One of the legs has oil and the other is air. I would need to know the oil's correct viscosity and quantity. I have partially stripped it and drained all of the oil. I refilled with the same amount of oil in 2.5w (measured from the top of the tube). The fork still seems too harsh over lighter corrugations but works well on bigger hits. Adjusting air pressure does not make a difference. The correct service procedure would also be very helpfull. Thanks!!!
David, send a PM to Johan Bornman. I'm sure he'll be able to help or guide you in the right direction.
How's Slummies ?
You still working for Gavin ?
Let me know if you get stuck. We bring in RST forks and we have access to the RST Taiwan Service Department. Kiwi2009-05-29 03:30:08
