Any help would be greatly appreciated...
I had to open my front caliper to remove something that got lodged in between the pads causing my brakes to stick. When I closed up the caliper I had lost power to the brakes as air had obviously weaseled its way in. Is there a way of getting the brakes to work or do i have to bleed to get that one tiny drop of air out?
Thanks,
Pistol
I vote for bleeding as the only option, if you opened the caliper that little bubble of air is probably not little at all.
Daxiet2009-09-22 03:46:06
