Hi Hubbers
I am riding a Speialized stumpy with a Fox Triad rear shock.
What pressure should I be riding with? I have read the Shock set up manual and watched the video. I am running it at 250 PSI which drops to around 240 when I unscrew the pump. I Weight 96kgs and the rubber washer is sitting at the bottom of the shock at the end of each ride? Is this normal or is the pressure to low?
