For those with fitness devices such as the Edge, an updated version of the Training Center has been released. Change Log:
Changes made from version 3.4.5 to 3.5.1:
Added support for Garmin Edge 500 cycling computer.
Added the ability to display power data when present in user activities.
Added the capability to import gpx files as activities and export activities and courses as gpx files.
Fixed issue where a user would be repeatedly required to choose between the application and device user profile during user data transfers to certain devices. This could occur in situations where the resting heart rate was set in the application's profile.
Fixed issue where transition information would be removed from a Multisport activity if the activity was dragged and dropped into a different folder.
Updated map drawing code.
Deprecated support for Forerunner Logbook files.
Improved application auto-update feature.
Fixed issue where application could have a fatal exception in certain situations during program exit.
Fixed issue where importing certain tcx files could cause the application to crash.
Fixed issue where application could fail in certain situations when reading in workouts with steps with power targets.
Download link: http://www.garmin.com/software/TrainingCenter_351.exe
  • Added the ability to display power data when present in user activities.
At last. Unfortunately, they still haven't added the ability to set power zones and create power-based advanced workouts within TC.
