Power to weight is the amount of power you can output over a particular duration divided by your weight (usually bodyweight).
If you can average 450W for 5min and weigh 75kg, your 5min power to weight ratio is 6W/kg.
When they quote power to weights for pro cyclists, they usually refer to threshold power i.e. the max power they can sustain for 60min.
More info:
http://home.trainingpeaks.com/power411.aspx
Your power to weight ratio is one of the most acturate ways of measuring your increase fitness and performance. Buying a Power Meter - even a Polar CS600 for starters will allow you to monitor your progress with much more accuracy and makes training a lot more focused.
