Centerlock (advantages):
Ease of use (easy on, easy off)
Less sensitive to torque and alignment issues
Lighter hubs
Can run centerlock OR 6-bolt rotors
Two-piece rotors (heat dissipation)
6-Bolt (advantages):
More hub options (anywhere from no-name to top-shelf)
Price
Less tools (torx on multitool, vs cassette tool)
Lighter rotors
Lighter
I really do not think so. 6-bolt you can get down to 60gr for a 140mm off the shelf.
I don't know why you would want a disc that you can take off easily. You fit discs once in about 3 years. 6-bolt is also cheaper.
If you compare like-with-like, it's lighter. Take DT-Swiss:
240s (No disk) = 108
240s (6bolt) = 154
240s (Center) = 136
Obviously with a wider variety of hubs, you'd expect 6-bolts out there that are lighter and heavier than any centerlocks.
Very good point on the price. I've edited the post...
Sometimes you need to take the rotor off to service the hub bearings... (Don't know if this is the case with 6 bolt)
Easy on - easy off is a nice plus here... just note it's not idiot proof. You can miss-align the lockring if your not careful and then manage to strip out the thread of the hub... :mellow:
Lighter
Can run centerlock OR 6-bolt rotors (with adaptor)
+Price
actually 6 bolt is lighter (no adapter and no heavy rotor)
240s (6bolt) = 154
240s (Center) = 136
Okay a bit of misunderstanding from my side. You were talking hubs and I discs. Okay, now take those lighter hubs and add the heavier discs. Then all is even again.
To install bolt-on you need a cassette tool. To install 6-bolt, you need a multi-tool. Most multi-tools these days have a T25 on.
Lighter hubs
Price
Lighter rotors
Lighter hubs
Price
Lighter rotors
More variety of aftermarket discs
That one will have to go in the Centerlock column too!
Centerlock = Any Centerlock disk +OR+ any 6-bolt disk.
So the wider the range of 6-bolt disk options, the wider the options for centerlock too.
Technically true but then you go heavy again and you need to fork out R200 for 1 adapter.
