Shimano Crank Arm Fixing Bolt / Shimano Crank Arm Replacement Non Drive
Hi, Im looking for these spare parts for my Shimano XT crankset
http://www.chainreactioncycles.com/Models.aspx?ModelID=5095 or http://www.chainreactioncycles.com/Models.aspx?ModelID=32877.
Not sure which is the right one, or if they are actually the same thing, one branded the other not? IS it possible that I can get these in South Africa? If so would my LBS have them or do I need to contact the Shimano agents.
Many thanks.
They are available locally. Crank arm fixing bolt part number Y-1F8 11000. If you can't come right contact colin at coolheat.co.za. I have a Dura-Ace one that's aluminium spare that I bought to replace my black Ultegra one but it doe not fit but it does fit the XT cranks. Only problem is it is not hollow so gunk can build up in the crank spindle.
