Got one of those. All new FD come with spacers so will fit onto the meteore frame. The seat tube is pretty narrow so you won't buy one that is too small. Just make sure you get the correct mechanism, my bike isn't here now but i think the right one is the bottom pull, not the top pull. For some reason the position of the cable routing only allows for one of the mechanisms. Most LBS should stock both types though...just check before you decide to buy online and get the wrong one, which is what i did.
I reckon, but if you're not sure buy it and get it fitted at you local bike store as they will then definately give you the correct one. I do think it take a bottom pull.
If it is the one in the link I posted then you will need a top pull. But with Shimano it does not matter. The same changer can be used for both.
