This is how I do it:
Remove lenses:
1. using the soft cloth lense cleaner I hold the lens firmly between thumb and forefinger.
2. with the other thumb and forefinger I pull the frame downwards (the bit that rests on - or closest to - your cheek) to open up the "eye socket".
3. at the same time wiggle the lens but concentrate on pushing it outwards.
4. be gentle but it does require a bit of force.
Putting in:
1. line up the lens aiming the inside (nose side) first.
2. once in, gently push the rest of the lens into the frame.
3. make sure it's all clipped in properly by trying to remove the lens gently (see above but leave out point 3).
