What do you call and where in Pretoria can i get those meggaftertjies that you use to rout brake pipes on a V brake frame. Can I fit the pre bled Shimano brakes to them?, ie how do i get the brackets over the pipe without undoing them?
Also in the pack are little washers that fit on the disk caliper mounting bolt where you can thread a wire through to retain the mounting bolts.
I used Shimano housing guides and they worked 100%.
http://www.biking.com/files/cache/shimano-disc-brake-hosesupport-guides_98329ab18f3f7a214df7e406bf130c3f.jpg
And it's not a washer but the bolt that has the holes through the head for the wire. I never used it as it normally comes with XTR, but my XT came with plastic plugs that wrapped around the knurled bolt heads and over the ends of the caliper.
Here is the Shimano bolts.
http://www.chainreactioncycles.com/Models.aspx?ModelID=17907
Here is the wire
http://www.chainreactioncycles.com/Models.aspx?ModelID=17564
Have a look at this PDF p8-10
http://www.bbinstitute.com/dl/dx_demo_chapter_37.pdf
